Additional driving lights -- wiring
  • Thread starter Thread starter locp10
locp10
I have added a couple of driving lights to my GS, the last job (assuming they have to switch on/off with the main beam?) isto tap into the main beam somewhere with a feed to my relay. Where,s the easiest place to do this, has anyone got a trick.
I assume the relay tapped into the headlight wont make the Canbus have a fit ?
Taking the trigger feed for the relay from the main beam will not cause any issues with the can bus.
If you look under the headlight unit you can get the wire inside the headlight through one of the existing entry points.
On the bike earth is brown so finding the live feed is simple enough.
