Adjustable gear lever
cjw
North Lincolnshire
I'm looking for an adjustable gear lever for my 2012 TC GSA.
Motorworks have two on their site,both are the same price,one is a Wonderlich,the other an unknown make but they look very similar.Has anyone used either or has any other recommendations ?
Craig
Craig
I have the wonderlich lever because I needed the extra length to compensate for wide pivotpegz. The lever is well made and looks good but is expensive.
Alan R
Do you realise that the standard lever is adjustable, at least to a small degree. The toe piece is on an eccentric cam, and I believe the whole lever can be moved either on its splines or by adjusting the connecting rods.
Exactly how much adjustment do you need?
Thanks for the advice Alan.
Steve,I was aware that the toe piece is adjustable unfortunately it's still not enough at it's farthest setting,I need at least another inch
....don't we all!!
Craig
....don't we all!!
Craig
Do you mean another inch up and down or do you need it an inch wider, as said above move it on the splines for up and down, I did this to accommodate my motocross boots
Cheaper than a new lever.
I have my gear lever set as a compromise for touring boot or MX boots. But its never quite right so a quickly adjustable gear lever would be great to have. Who knows if such thing exists.
Hi
Whats the maximum length that the Wunderlich lever extends to?
Craig
130mm from the centre of the gear lever spline to the centre of the lever end peg.
Alan R
Alan R
Thanks Alan
That info has saved me some money!
130 mm is about 5mm or so longer than the standard lever,which isn't enough.
Looks like it will have be a Touratech version as I think they extend to 200 mm,although I don't think that they look as good as the Wunderlich ones,hey ho!
Thanks again
Craig
Thanks Alan
Thanks again
Craig
Blimey, what size are your feet that you need one that long ? :eek:
