Adjusting foot levers
Big-G
North Wales
Hi, I’m looking to adjust my foot levers slightly to give me a little more comfort when changing gear etc. Looking at the gear lever it’s just a normal two ended rod if that is correct. How does the brake lever adjust? Any ideas. Cheers G
Other than the flip down riser on the GSA, there is no other adjustment for the standard BMW foot brake pedal. Some have adjusted the pedal to piston rod, but this is not advisable as it can make the brake bind.
As Victor says above I would not touch the rear brake pedal or you could get smoking rear brakes and a warped rotor
I’m looking to dropping both as my size 13 sit too far below as std. maybe I should go adjustable gear lever but I’m sure this will adjust as std. the brake I’ll live with.
