Adjusting the RH mirror arm.
alp
SW England
Just in case you want to move/adjust the RH mirror arm bear in mind that the lock nut you have to release first is a LH thread. Presumably to avoid wind pressure loosening it off.
Maybe this info will save someone trying to undo it the wrong way and giving themselves a hernia in the process.
They all do that Sir
:rob
All makes and models
As expected and typical of this forum, you put up something which you think may be of use and someone is ready to pounce and feels duty bound to diss it. By the way, NOT all bikes are like this, maybe just the ones you've had.
Cue more comments.....? :D
