adler mount block
rovert57
WIRRAL
hi everyone just received an adler sat nav mount for my gsa was wondering what the thread size is for the nine small holes on the front of the unit .what are the thread size on the garmin zumo mounting bracket thanks in advance for any help with this query .
any photo's of this type of mount would be helpful
here is a pic of the mount
also which bar does it mount on .
The holes are positioned to accept a Garmin GPS cradle. Did you not get screws and spacers with the ALDER (it was a combination of ALAN and DEREK) mount?
The block should fit the windscreen support bar on an R1200GS Adventure or fit onto ALDER's own GPS mount as in this pic of my 2011 Twin Cam.
thanks schtum
only got the block thats at the top of your picture so it might fit the one of the bars on my gsa will have to make a bracket to fit my nuvi sat nav
thanks schtum
Which nüvi have you got? I know there's a RAM cradle for 700 series, i.e. 760 / 770 models that will fit onto the block. Here's the one I've got which I used to use to mount my nüvi 770 on a RAM Mount. Having done a quick search there are RAM cradles for other models of nüvi as well.
Hi i've got a nuvi 250 & 4595 so if you have a part no that would be great
Thwnks
Sent from my SM-G357FZ using Tapatalk
just thought I would report that the thread size for the adler mounts 9 small hole are 4m ,best get the 16 mm length .to be able to mount my car nuvi sat nav I bought a ram mount base which has four holes that line up with the holes in the mount itself , so will make do with this set up for a while .
thanks for the advise .
