Advance Guards V2
yofi
Midlands
Message from Andrew at MA
To our many patiently waiting customers:
It has been quite a while since you have contacted us about your interest in the ADVance Guard v2 Multi-functional Hand Guards. Now that it is 2021, a year that will be more positive than the last, I want you to know that the ADVance Guards are finally being manufactured and that we expect to have products here in late February or early March.
Much of our effort and testing was directed toward selection of a new Guard frame material, one that is much more resilient to the application of force and that will hold together after a drop. A long testing and tweaking process was needed to arrive at a formula that works.
Yes, we must wait a little bit longer, but they will be here for the start of the riding season in most parts of the country. Thank you again for your continuing interest and I will keep you up to date over the next two months.
Regards,
Andrew Serbinski
MachineartMoto
Sounds like they are looking for a cheaper solution than the cast alloy of v1. Plastic? Hmmm.
Glass reinforced plastic?, ABS,
loads of other options, its the tooling change that may be the killer
Depends if its a one shot / multi cavity/ up and away tool
