You can use a K-series front wheel for this conversion.
A small update, but one that might be welcome news for some: it is possible to use a K-series front wheel on R-series.
I've been meaning to check this out for some time, and last night I finally made some time to do it. Some notes:
1. The brake-disc mounting surfaces need to be machined down by 3.5mm each side. The brake disc PCD is universal between F-, R- and K-series, so the 305mm GS brake discs will fit a K-series front wheel.
2. There is at least 5mm of clearance between the wheel hub and the fork legs.
3. It's easy to get the latitudinal spacing of the wheel hub correct in relation to the fork legs, because like R-series, K-series wheels use hubs with symmetrical side-to-side dimensions (it's only F-series hubs which are assymetric).
4. The wheel bearing inner races are exactly the same dimensions between K-series and R-series. This means a perfect fit between the races and axle.
5. After some careful thought, I decided the way to go would be to use an R-series front axle and axle spacer.
The wheel-bearing race outer surfaces are spaced 90mm apart on R-series, but at 130mm on K-series. This means that for the axle and axle spacer to locate the wheel properly, the wheel-bearing race outer surface contact point of the front axle needs to be machined outward by 20mm (at a diameter of 25mm for the race to be located properly).
6. The front axle spacer likewise needs to be reduced in width by 20mm. I'd suggest taking material off the OUTER end so the oil-seal contact surface stays intact.
7. You won't be able to use R-series oil seals on a K-series wheel - the dimensions between both are totally different.
I haven't yet looked for oil seals that will do the dual job of locating properly in the wheel hub while sealing against the axle and spacer (different seals will be needed for left and right), but it shouldn't be a labour of Heracles.
...This clears the way for me to use my spare set of K1200S wheels for another GS 'Moto conversion.
Me be happy bunny!
