Niall:
If you are willing to consider buying a used (second-hand) SP III, there might be some very good deals around, either on this BB, other moto BB's, or on eBay or similar. The GPSR's don't really deteriorate or wear out, so there is not much risk associated with buying a used one - if it works OK when you look it over, then it's going to work pretty well for the foreseeable future.
Here's sort of a "quick checklist" for doing due diligence for the purchase of a used SP III:
Basemap - Make sure it's a European basemap model, not an American basemap model. You can check this by removing the memory chip, turning it on, and zooming in to about a 10 mile or 10 kilometre scale on any area in Europe. If you see roads, it's a European model. The American models only show political borders for European countries.
Memory Chip Size - You will need a 128 meg memory chip. These have come standard with the SP III's in the last year or so, but early models came with 32 meg chips, which are way too small for today's map sizes. The little chips that the Garmin units use are proprietary to Garmin, and quite expensive. If someone wants to sell you a unit with a 32 meg chip, you will need to heavily discount the price to offset the cost of buying a 128 meg chip.
Map CD with Unlocked Regions - SP III's sold in the last year or so have come with a CityNavigator Europe version 5 CD, with an unlock code that unlocks all of Europe. The original SP III came with CN Europe version 4 and an unlock code for one region only (e.g. UK, France, German speaking countries, etc.). If you get CN 5 with all regions unlocked, you could probably live with that without having to upgrade, although it will be one year out of date. If you get a unit with CN Europe version 4, you will have to upgrade to version 6. An update to CN version 6 (from either 4 or 5) will cost you USD $150 from Garmin (see this link:
Garmin Cartography Updates) Note that the upgrading process is kind of strange, first you contact Garmin and they send you an upgrade CD (free of charge), second, you buy a code to unlock the upgrade CD. You can buy the code from either Garmin direct, or from a Garmin dealer. In North America, the Garmin dealers discount the price of the upgrade unlock code quite a bit, so shop around and see if you can find a lower price for the upgrade unlock code, which is simply a piece of paper with a number on it.
Unlock Codes on a Floppy Disk - The original purchaser must give you a floppy disk to which he has exported the
original unlock codes for the CityNavigator software. Otherwise, you won't be able to use the maps on your PC, or upload new maps to your GPSR.
Note Carefully: You can't make use of any updated CD unlock code you have purchased unless you already have the original unlock code for the earlier version installed.
Condition of screen - The SP III screen has a quarter wave dichroic coating on it that is quite susceptible to scratches. Make sure the screen is in reasonable condition (not scratched) and the coating is still there (not polished off). A replacement front cover (includes the screen cover) will cost you about USD $25 from Garmin UK, you need to send the GPSR in to them to have it replaced.
Watch for Scams - There are a number of scams to watch out for when buying a Garmin StreetPilot. Here's just a few:
- You want a StreetPilot III, not a 'StreetPilot' or 'StreetPilot ColourMap', which are not the same thing.
- Make sure you get the original map CD's. If someone tries to sell you a GPSR without the original CD's, they are playing games.
- Make sure the CD's you get are "CityNavigator", not "City Select" or "MetroGuide Europe". Only the CityNavigator CD's have the detail on them that the SP III needs to fully perform.
- Vendor must be willing to allow you to re-register the Map CD's and Map Unlock codes to your name with Garmin. If they're not willing to do this, they are scamming you, or you and Garmin.
Anyway, just some thoughts for you - the SP III's are selling, used, for about USD $400 or so in North America. The cost in Europe will be a bit higher (original retail price was higher for the European ones), but if you can find the same thing as the store is selling for 40% off, and it is in good condition and everything that should be there is there, then you have the possibility of saving a lot of money.
PanEuropean
