NicD
Who do you think does the recon units for MW..somebody must be?
Nothing to see here,move away.
ah ha!
Doubt it , I had the recall , once the recall was done I had a note from the dealer declaring slight play noted. No offer of seals , bearings to be done , didn’t want to know , I believe the official BM route is to replace the whole FD with a shiny new one££££££ , I would really like to know the failure rate for this turdish design piece.You know. My original has not had the recall steel disc carrier done. I wonder if I could send in a 15 year old bike now to get it done. They might fix the input seal cheap.
Can anyone confirm that. Replace the lot??
AgreedAdvice needed please. Final Drive woes.
I have looked at the replies the OP has got to his request for advice and they are all giving sound advice but the OP
seems to have completely ignored all that good advice and gone/is going his own way anyway.
The point of asking was?![]()
Agreed
Most likely trying to save a £ or two , nothing wrong with that.
I've learnt that you have to factor in sprockets & chains every 15k or so on bikes but in a GS a FD rebuild every so often , that's life, one thing for sure they are not maintainance free , had problems with my R65 play on shaft , bearings on my R1100,R1150 though I could do them at home , my R1200GS which went to MB , funny my R100RT mono reached 65K without any problems.
Saving money where it can be saved is fine i agree but here in this case you might save money initially but, if you
want to keep the bike it's likely it'll come back around and bite you in the bum, eventually, costing you more money.
I've had FD's on two of my 1200gs's rebuilt by Mikeyboy over the years including my present one which was done at 60K and only because i detected a small amount of play in the pinion shaft
meaning it was likely the needle roller nose bearing was giving up and you don't want to run that until it breaks upso i got it off to be rebuilt, now done 72k and both have been fine subsequently.
Wish I had a chain and sprockets now!
