TobyH
I know this has been covered over and over again but: - I have been very pleased with the smoothness etc since fitting the Y piece and I think I have done all that you have recomended in the past but fuel consumption is much worse ie. perhaps 40mpg. I re fitted lambda,removed the jumper and reset the thingy as has been described in the past. I havn't re balanced though, I just had that done at 6000miles. I know it may need it again after the mod but is it likely to make this difference? What kit vacume gauge, etc should I get as I would like to be able to keep a check?
