Got a slow puncture attempted to re inflate with compressor via adaptor under seat initially it worked then cut out. Stripping wires and direct contact to battery sorted it out. Is this the canbus system stopping it working
Did you leave the engine running at the same time, my compressor for pumping up airbeds has never cut out with the engine running but has on occasion with it not running,
Just run the engine whilst using your inflator via the canbus socket. That will stop the socket from shutting down and will give the pump a little more grunt!
You could also lose the sight glass and end up with oil all over place if bike is on and not movingJust run the engine whilst using your inflator via the canbus socket. That will stop the socket from shutting down and will give the pump a little more grunt!
