Air Con
Mzokk
Belfast NI
My ford Galaxy needs a bit of work doing to the Air conditioning. Anyone know or recommend someone who actually knows what they are doing with air-con??:) Ta M.
Does it need gassed or work done to the pump M?
Most transport refrigeration places can gas the AC for much less than a car dealer and they would usually have a good working knowledge of different systems.
I used ballymena auto radiator specialists and they seemed to do a good job and were easy to talk too!!
Ricky Pollock is the boss and number is 25658000
do you have quik fit your side of the irish sea they will gas it up for you
No not just gas the pipe from the compressor has fractured.......which means since I haven't used it since last summer the dryer may be u/s. I'll try and get hold of the pipe and get it gassed and see what happens! Good call on the transport boyo's I'll try give that a try! :)
