No mention of XR650R forks? I've fitted them to my paralever, bottom head bearing is the same, a 25mm thick top hat spacer (IIRC) at the top and 75mm (again IIRC) preload spacers inside the fork legs so they were the same length as the original BMW forks. The 320mm supermoto disc on the cross spoke wheel needed a rotor bracket and wheel spacers made.
I thought I'd posted threads about it on here but I don't seem to be able to find them.
