Akrapovic Exhaust
Hoff
Old Submariner
Denmead, Hants
I have a 1200GS TC fitted with a full Akrapovic system and am looking to quieten it down a bit.
Does anybody know which noise reduction insert will fit and if so where can I source it.
I look forward to receiving a full broadside but hope some positive suggestions as well.
Paul
I got a 'decibel killer' from http://www.pjengineering.co.uk/
Fitted fine to my cobra exhaust on an 1150 gs 3 years ago made just the difference I wanted (takes the edge off)
Also bought baffle material etc - lots of good bits and bobs on the site and they were good to deal with.:thumb2
Measure the outlet tube inside diameter then go on eBay and find a baffle to fit. If its angled you might need to get it cut and welded.
I have 48mm did outlets which will take "standard" universal baffles but they do cork up the system. I found that 30mm fitted on mounting spacers will fit down the pipe without any cutting and although they are far from blocking the gas flow they make a big dent in the noise levels.
