Akrapovic system set up
trancey
North East
is there a favoured fuelling set up for an LC with an Akrapovic full system? Options appear to be do nothing, Power Commander V or ,Hilltop tune. What have the people with full systems done and do their bikes work well?
I wouldn't 'do nothing' :)
If it's a full system, it's in your best interest to i/ finish the job properly and ii/ make the bike a bit richer to protect it. I personally went the Hilltop route, some others have gone power commander. There's probably not much in it to be honest, but either are definitely worth doing.
:thumb2
Do you know if disconnecting the lambda sensors when fitting the PCV gives errors on the dash and in the ECU, which will be visible when servicing?
Errrrr .. No! I don't know.
Hilltop it! Much easier ..!
Other company's can tune these too.
Just done mine and had remap by Elite Remaps.
There will be fault codes for the exhaust flap servomotor ,doesn't put any warning light on,and no other effects.
If you disconnect any component there will be fault codes.
Leave the servo motor there, just take out the cables and seal up the holes where they were. No fault code cos it does not know it's gone.
Your wrong, without cables the travel of motor is different. A fault code is set on start up.It does not affect anything and no warning light.
This is using Icom
I've done exactly that.......
This is using Icom
No fault codes reported by my dealer after a recent service :nenau
The probably don't even check for fault codes at a service if theres no complaints .
And if they do they will see you have no Flap fitted so no further action required.
They never mentioned mine.
All you need to do is type in Hilltop into search and enjoy several days of reading, it has been done to death already.
