Sold AltRider Lexan removable headlight guard R1250GS / R1200 WC
HGS
Wrexham
In black
AltRider & Adventure Bike Shop list these for both the 1200GS water cooled and the R1250GS, but as always, check
This was fitted to my 2022 R1250GS
I choose this one as it can be taken off in seconds.
Held in by 4 aluminium ball and rubber sockets
Solid when fitted
couple of very small marks from debris on the polycarbonate face. Can't be seen when fitted.
£65 PP FF or bank transfer
https://www.adventurebikeshop.co.uk...-black-for-the-bmw-r12001250-gs-water-cooled/
https://www.altrider.com/altrider-headlight-guard-kit-for-the-bmw-r-1200-r-1250-gs-gsa/pid/1666
Heres the blurb
The resilient face of the headlight guard is precision cut from impact-resistant polycarbonate – the same material used in bullet-proof windows. This polycarbonate is formulated with a hardened scratch resistant surface both front and rear. The face attaches to the stainless steel frame with a custom machined aluminum ball and rubber socket connection that provides a sturdy connection free of any vibration. These innovative fasteners make removal of the guard for cleaning a cinch – no tools required. The polycarbonate guard is also interchangeable with all other versions of the AltRider headlight guard.
The stainless steel frame of the polycarbonate headlight guard is anchored on all four corners of the headlight to provide a robust foundation to absorb impacts. Unlike other available headlight guards, installation is simple and doesn’t require removal of the blinker stalks or any bodywork. The top is mounted using OEM bolts while the bottom uses provided stainless steel hardware. The metal frame is laser-cut and grain finished. The frame is available in brushed stainless or powdercoat black finish – both are incredibly resistant to rust and weathering. The headlight guard will fit both the halogen and LED headlights.
  • All AltRider products are 100% designed and manufactured in the USA
  • Polycarbonate face resistant to impacts and is specially treated to harden the surface to resist scratches
  • Custom machined ball and socket connection allow removal of face without any tools
  • Polycarbonate headlight guard interchangeable with all other versions of the AltRider headlight guard
  • Stainless steel frame provides strong foundation and is highly resistant to rust and weathering
  • Compatible with halogen and LED headlight
  • Frame available in brushed stainless and powdercoat black finish
  • Compatible with R1200GSW Adventure
  • Compatible with Rallye and Exclusive models
NOTE: Polycarbonate will react to certain chemicals and requires specific care to clean correctly and keep looking good for the long haul. Cleaning improperly can result in scratches, hazing, surface crazing and cracking.
If the BMW LED Light Bar is fitted you will need to knock out the top hat before fitting the Altrider Light Guard.
Bump before Ebay at the weekend
PM me if interested as I don't thread notifications
:thumb2
Sold and paid for
Thank you
