An airhead has sneaked into my garage!!!
Paul S
East Midlands
This is now in my garage sharing space with my WC but not mine ;)
It's actually belongs to a good mate of mine over from Dubai who was at the Classic meet at Mallory this weekend.
He managed to crash it coming out of Edwina's (I know that feeling :augie) and so has left the bike with me to sort before he comes back in August.
Nothing major to sort that I cannot handle except all the ali framework for the fairing needs to be re-welded:
Any recommendations of someone around Notts/Derby who can sort this?
Welding to fairing supports sorted by GIA in Stapleford - would recommend them :thumb
Going to do an oil and filter change on Helga this weekend but no idea how to get at the oil filter (over 25 years since I had my last airhead!).
Is this typical or has the engine been raised in the frame which makes access worse? Any ideas appreciated :thumb
Well gave it a go but no way of getting to filter with engine in the frame :blast
Engine is very tight to top frame tube with engine casing cut to fit:
Removed front cover, front engine bolt, tilted everything forward:
....and still no way of getting the filter out:
Gave up and put it all back together and just changed the oil for now :augie
You don't see many with the normal low engine mounts ground off the frame and then re-weleded onto the top of the tubing !! Obviosly a ground clearance theory ( but putting weight higher up ? )
I think you did the right choice re oil change.....change regularly and if unfortunately the filter clogs, there is an oil bye-pass channel !
Nice bike.
Nice bike.
Thanks that was going to be my next question -will advise my mate to just regularly change the oil for now.
