Another Autoswitch AS7 fitting question
haydw
Preston, England
I have an existing set of fogs that are powered by a relay with a toggle switch, but it occasionally chucks a wobbler if it gets really wet so was going to change it to an Autoswitch, the earlier thread and instructions show how it's fitted. Ok for one set of fogs.
I want to add another set of fogs. I know I will need to fit another relay and wiring, but is it possible to control both sets using one Autoswitch so I turn on on set A, then turn on A and set B then turn off set B then turn off A.
Looking at the instructions for the Autoswitch you can configure for long indicator press or double tap. Would I need two autoswitches, one set to each method to control both sets of lights or can I control them with one switch only?
An Autoswitch only has one relay connection, so you'd need one Autoswitch per relay to be controlled.
