Another re-valveing thread
Mike Wilkins
Godalming, England
I plan to get K-Line valve guides fitted - as recommended by Tony Pastyman, when http://www.cylinderheadshop.co.uk/ re-open for business in Feb. as they're just down the road.
What valves should I use ? are the cheaper Swiss Motobins ones ok ?
What else should I change / consider whilst the top end is apart ?
I guess its an opportunity to pull of the cyls to check stuff (esp. having seen it done at the wee-kend !!)
MIke
If you mean the bronze inserts my understanding is that you shouldnt fit them into bronze guides so that is a no no.
The Moto Bins valves are not cheap - it is the BMW ones that are three times the price they should be - nothing wrong with the Swiss Intrvalves or Moto bins guides.
Motoren Israel sell them for a bit more than 'bins if buying cheap is a real concern to you.-----.
