PatrickMullen
I've spent weeks reading posts and testing the unit, but I want to be sure before I pull the ABS off the bike completely.
Bike in question is a 2003 R1150 GS Adventure
The problem
Is there anything else I'm missing here that could cause the rear brake to die? Thanks in advance to anyone who dares venture into yet another iABS II thread
The problem
- Rear brake is in residual braking mode: no sound from the servo when the rear brake pedal is pressed. Stopping power is the same with engine on as it is with engine off in the rear brake.
- I get the following lights on the dash: Gen ON, ABS flashes at 4Hz =At least one brake circuit in residual braking function mode.
- Front brake works fine. The servo whines as normal and I get far more power when the bike is on vs off
- Issue arose as I pulled the front brake to come to a stop at a set of lights. Loud squealing sound, followed by a harder grab of the front discs than normal.
- Went away after a day, bike was fine for a few days, now it's gone completely in the rear.
- Battery voltage is OK, on start-up and up and while running
- ABS sensor gap measure ok both front and back
- Tail light works perfectly—both parts of the bulb are illuminating when either brake is applied
- Hand protector is clear of the lever for front brake
- Triple checked the brake switch and cleaned contacts, made sure the pedal is closing the switch fully, it is
- Micro switches both working. I've tested them at the ABS unit, and I can hear them when the lever is pulled a small amount (light "pop" at the unit)
- Brake pads are new
- Fluid has been flushed—incl. brakes, module and reservoir under the tank. Done in correct order, twice.
- Made sure the "big plug" is connected right at the top of the module. Cleaned contacts.
