Oh Dear!. I hope the weather improves. Sunny again here.
This is getting quite difficult and I should know having been in a similar place before, and occasionally now as well.
If you have a thermometer take an ambient air temperature reading and measure the resistance across the terminals on your air intake sensor: This may tell you if that component is about right. I've done this before and could find the results within this section.
Another component which feeds temperature information back to the Motronic is the oil temperature sensor but I don't know the strategy used by the ECU to deal with this.
Please remind us if you have checked your fuel supply output, i.e. looked at the fuel dispersal from the output of the injectors whilst cranking the engine or with a battery.
There's one more thing I'm loathed to suggest within the fuel supply system, and that's the fuel pressure regulator which I replaced but, did not help.
Lastly, are your TB's gummed up?
