Having built flying machines with pop rivetts and ali, I would chip in that it's well doable.
Ali is best etch primed with zinc chromate (for heaven's sake wear a gas mask as it contains a well known carciniogen). ZC, when sprayed very sparingly will both etch for GRP attachment and protect against corrosion.
I personally put more faith (for structural etch -GRP joints) in abrasion with emery cloth. Again this has to be done carefully in aircraft.
Disimilar metals do react and is best avoided.
Ali is not weak at all when used correctly and of course has the advantage of lightness and is easily worked. There will be applications in aircraft where, of course, it is not suitable..such as control columns etc..crome moly being preferable.
However, ali rivets are not necesarily the right things to use on certain joints. Harder rivets are used and dipped in yellow gunk...Iv'e forgotten the name of the stuff..to prevent corrosion.
That's my two cents....but I'm an amateur
Ben
