Any engine dfference r100gs 1986-1990<> r100gs 1991-1996?
  • Thread starter Thread starter seppe
seppe
Hello
Does anyone know if there is any diffrence between the engine parts or engine construction of the 1986-1990 r100gs motorbike-engine and the 1991-1996 r100gs motorbike-engine?
(How to recongnize this, if there should be indeed some difference between the engines of those motorbikes?)
:rob?
About the only change that I'm aware of is the introduction of the PAS. IIRC it was introduced as standard on other than US-Spec bikes at some point towards the end of the production.
Main difference is the quality of metal used in the last crankcases.
fecking Monkey metal :mad: studs pull out for a pastime:spitfire
Otherwise closed circuit breathing [white tubes down the inlet tracts ] or exhaust rebreathing on Merican ones, then ALL of the last ones :(
lighter flywheel was 1982 I think..
I've fitted a 1986 r100 bottom half engine into a '93 100GS cos it's better made from proper materials...:augie:rob
