Any friendly welders in Ards and north down .??
Geno
Northern Ireland
Want a little bit of welding done , its a bracket for a heavy wooden gate . Have bits ,just need a welder to finish the job . Thanks in advance Geno .
Do you use hickory or maple electrodes for that? :confused:
Al :D
try Jimmy Jordan on the comber road. If you turn in towards the old crepe weavers factory through the security gate and as you look ahead you will see some second floor offices which you can drive under. on the right of this you will see a white shed with a set of blue doors. thats his place
There's a guy in Bangor called andrew jones who used to work under the business name of Metal Guru. He now has a gardening business but still does bits of welding....good bloke and excellent welder....if you can find a number for him.
