Anybody Got a Centre Stand Stop/Buffer/Bung/WTF
Cook1e
The High Pennines
Hi Chaps,
I have spent most of the day removing my stubby tailpipe, catalyst and downpipes and fitting a Laser Duo-Tech system (courtesy of MerrickCampbell of this parish). Only one exhaust stud to drill & Helicoil, result!
So, very pleased with the way it's all come together and the resulting free-revving performance is excellent - a different bike. Dyno here I come... :D
I may need to sort out pannier heat-shields and tailpipe extensions in due course, but my immediate problem is the centre stand stop which was on the catalyst housing. The Laser manifold does not have a stand stop like some of the Y-pieces I have seen, so the cross-brace of the stand is currently stopping on the manifold, underneath the sump. :blast
Has anybody got a discrete/separate/standalone centre stand stop they are prepared to part with or information which may lead to the apprehension of same?
All advice, pisstakes, stupidity and irrelevance gratefully received :rolleyes:
Last time I had this problem (not on a GS) I used a black rubber doorstop - fastened it to the stand.
Ta for that, I may use it if I can find something for it to butt against that doesn't run at 500 degrees C. :thumb2
Hi Chaps,
you could yous one of your rubers between your engine and baschplate I think ! dont for get to put coperpaste on your lambosondas threads and un plug your baterry and the engine managment will reset its self to the new changes :thumby:
Bashplate removed to fit the Laser manifold - that's why the stand is resting on the exhaust. Used Optimol TA on the lambda. Thanks for the tip for resetting the Motronic. :thumb2
bump stop
Hi Chaps,
go to b&q loads in there:bounce1
Not the same issue, but a good replacement for the standard rubber stop is half a broken sump plate mount, bolts onto stand and bobs your auntie:beer:
r1150 GS have 2 bash plates just leave the smaler one on they look much better ah and if you tacke your rubers of your foot pegs that gives you a bit mor legroom and if you after tuning you can swap your 2 snorkel to your ingechtors for r1100s ones !!! and thier is a biger air intacke you can buy allso brisk spark plugs are ment to bring 5 Hp !!!!! my old r1150 gs yoused to go licke shit it would pull wheels in 3 rd gear with thies mods allso a K&N in place all thies mods wont cost you more than 200 euros best place to buy is M-Tech for price :thumby:
Due to living a mile above sea level, fark all I can do to make it perform more than moderate :blast
I live 700m above sea level but even in the dolimites which is any thing between 1200 and 2500m it would still run ok :D
Fixed! Cable-tied a length of high-temperature silicone tubing (sold as model aircraft exhaust tubing) to the centre stand cross-brace. :thumby:
