anyone know anything about piston/cylinder grading
cookie
Stay Frosty
Failed State
bmw seem to grade their nicasil cylinders A, B, C, but don't put a matching letter on the pistons :eek
they just have some numbers, presumably referring to size, printed on. does anyone have the info to match the numbers to the letters?
A 93.96mm
B 93.97mm
C 93.98mm
This is for standard pistons.
excellent :)
so any idea what .8 and 8.2 on the piston crown refers to? and more to the point, are they a match for B cylinders?
i would have expected a matching letter on the pistons, but there isn't one, or on the box :confused:
IME with other makes, a box contains 1 barrel, 1 piston, rings, wristpin etc. seems bmw do things differently. separately boxed barrels (marked as BMW), and 2 pistons in a box (kolbenshmidt).
Normally there is a code on the barrels, stamped on the outside, which you then relate to the piston size, ie a barrel stamped with a 'B' uses a 93.97mm piston, (which doesn't have a letter 'B' stamped on it, just it's size).
The 8.2 might refer to the compression ratio of the piston when fitted to it's designated barrel/cylinder head application, but I'm not 100% on this.
If you enter the piston's part number into realOEM (http://www.realoem.com/bmw/select.do?kind=M&arch=1), this will give you it's exact size hence you can determine which grade barrel it should be used with.
i should have realised earlier, but the sizes you're quoting are for an R100. these are R80.
i think you're probably right about the compression ratio, and i suspect the .8 refers to the last digit of the piston size, which is given on the piston box: 84.788.
i can't look up the pistons on realoem as they don't have a bmw part number, but i can probably work out the matching from there.
thanks for the help.
