anyone with a lathe and a bit of brass?
autogs
bookham,surrey
as title,due to shower fitting cock up,i need a brass spacer/tube,appox 14mm internal,approx 19mm external and 15mm long,any help out there or suggestions,
If it's plumbing it should be standard sizes what fitting do you ned it for?.
its a makti shower dave,i had to cut down the overhead tube where it bolts down to the glass support,due to a measuring error when i fitted the diverter pipe in the wall.anyway what i did not realise after i cut down the pipe is that the end was made with a integral spacer at the end which i cant get out of the pipe and i need to reinstate to fit it all back
measure twice, cut once :hide
yea i know,my father in law did the measurments but forgot to allow for the floor height,going to send the wife to a local eng firm on mon morning.going to fit a 5ft heated towel rail now.
its ok folks problem solved,local machine shop did it today for 15 quid.
now fitted offending shower part and all is good
