My bike had one of this fitted when I bought it, and a item of beauty it surely is too.
The sound with the baffle removed is simply awesome as well, so a double bonus.
BUT, I have to say that I am not very impressed with the carbon fibre support bracket.
Yes, it looks very trick, but it does not secure the can enough to stop it from moving.
As a result the can moves inside the bracket. As the engine moves backwards and forwards under heavy load/braking the can slides inside the bracket. So the rubber mounting bobbin is'nt actually doing anything at all.
The net result is that there are now score marks about 5mm either side of the carbon fibre support bracket.
I have just packed the bracket out with shimming steel, to try and get more purchase on the can. But after a quick test run, it has made little differance as the can still moves
I am worried about adding to much shim under it, as I suspect that the carbon fibre will not allow it, ending up with it breaking I suspect.
Anyone else had the same problem?
