Armour detail for Atlantis 3 trousers?
twobrowndogs
Leicestershire
Hi folks, I'm resurrecting a pair of BMW Atlantis 3 trousers .. they suddenly seem to fit. Thing is, I have removed the armour .. and .. er lost it.
Does anyone have Atlantis 3 trousers that they can photo the knee and hip armour please .. showing the part number. Mine are size 48 and pretty sure the knee armour is small whereas 50 on is large.
I have spare armour from old city 2 pants .. I could cut it to size. but can't be arsed.
Maybe you have some armour that I can buy?
Thanks for any help.
Don’t cut anything, it’s the same armour. I also have both. Is it yellow or orange in the City2? If it’s yellow is slightly shorter and narrower. But will fit. In the hip I have D30 ghost. I have a spare pair if you want for £15 posted. It’s level 1.
Thanks for the reply. The City2 is the Orange. My city 2 is Large (too large). I think the Large and Medium may have different size armour. It definitely doesn't fit the Atlantis 3 (size 48) without any mod. I'm pretty sure the Atlantis 48 uses size small armour .. but size 50 on uses large.
BMW have sold mw some yellow (but large) from a different pair of trousers. They didn't have any size 48 in anything to check the armour.
Did you have to cut up the D30? I am interested in the hip armour.
I was going to ping @Orinoco a message as he had a pair of size 52 .. would be interested to see what armour was in those.
Thanks lots
Thanks lots
The hip armor is the same size as the BMW one, I use it in my Atlantis 3 size 50. I shall measure the spare knee armor from the Atlantis, it should be the same size. I have both yellow and orange. Will post some pictures with measurements. I went over to D30, hence I have some spare ones.
Thanks, an image of the hip pocket. Added white tissue to show outline. Basically two pockets linked.
Sent from my SM-G973F using Tapatalk
Orange armour is from a 3 size 52 and labelled L. The yellow is from an Atlantis 4 size 50, it is also labelled size L. The knee pocket for the 4 is shorter by 2”. I can see the outline of the hip pocket is a different shape to the hip armour I have. Weird.
Anyway if you want these it’s yours for £30 posted.
Ha Ha, no such fancy armour in mine... I think. I've never checked the knee armour, but know the hip 'armour' is some reused Toolstation knee pads :)
The knee armor is massive. Goes around your knee and in length is about 40cm long. Only RUKKA does something similar.
Hi, that orange is same as my old City 2 (they are unisex large) and same as yours .. but too big for my Atlantis 3 (size 48). I now know that up to size 48 for Atlantis was a Small knee and size 50 up is size L.
I am guessing that if I had the small orange knees they'd fit .. I have found some small yellow .. so should work.
Yes please I will have the D30 hip from you please. Do I share my email here?
Also .. your size 50 Atlantis .. are you getting rid please .. pretty please ? My 48 is ok .. but needs "stretching" just a little.
Thanks lots for the info
Maybe get in touch with a Moderator and pass on your email/number to him? Or just create an email in in gmail, delete it after you are done.
Yes you can have the trousers. Atlantis 4, size 50. Treated and good to go. £120 posted.
Thankyou, replied.
