I've spent the last couple of weeks going to work on the bike, and although it hasn't been running properly, it's been running well enough to use since I had the injectors cleaned.
It's been hard to start, feeling like the battery was dead, so this week I put a brand new Exide in it.
It's been pulling off in 1st and second OK, but when it gets to about 4k revs, it started fluffing and felt like the fuelling was fekked up still....supply or something.
Oddly though, If I went to about 6500 revs then changed up, as long as I could drop into about 5000 revs in the next gear, it would carry on picking up...full power (or nearly full anyway) available
So for the last two weeks I've been looking for a fuelling issue.
I changed the filter for a nice shiny billet thing that I can take apart and clean, I changed the hoses for new braided ones, I had the pump out of the tank yesterday and found that the very short link pipe between the outlet of the pump and the metal pipe was showing clear signs of Ballooning.
I took it off, and sure enough, that bit of pipe was a non-reinforced type
, and the middle of it had gone very flexible and squidgy, as if it had been blown up like a balloon many times. So, having replaced that with some proper reinforced tube, and replacing the loop of tube where the internal filter used to live (mine lives outside the tank) I investigated the wiring to the 4 pin connection.
It's been totally bodged about at some point (not by me) so I cut it all back, took put the 4 pin connector and replaced that with two waterproof two pin Durite connectors arraned M>F and F>M so they cant be mixed up
When I put it all back together, it was exrtremely slow turning over, sounded like it was really struggling, even with the brand new battery on it, and then with double battery landrover jump pack on it, same result.......so out came the starter motor.
Looked ok, no smell of burning, wiring OK, so after a good clean up, I refitted it.
Earth connection?
Looked ok, but just in case, I ran a new 80 amp wire from battery neg to starter casing mounting bolt for a good new earth....
Turned over slightly better with jump pack but still struggling, and suddenly fired up and revved sweetly.
Thinking I'd finally solved the long running mystery, I set off for home a bit later.......and for ten minutes had a huge grin on my face........revved sweetly and pulled nicely through all gears to top, no spluttering, perfect!!
Then, it started coughing a bit, and within a hundred yards, was firing on only one cyl again, then died completely.
Called the AA, and with his jump pack, it barely turned over, so waited around for another couple of hours for a recovery truck and it's sat outside , dead again
Question....is it possible for an engine to partially seize?
I'm losing the will to carry on now
Thoughts welcome, but be gentle please
