Sold ASUS ZenWIFI XT8 AX6600 Tri-band Mesh Router with two nodes
Eastmidsbiker
Notts
"The ASUS ZenWiFi AX (XT8) is a premium, tri-band Wi-Fi 6 mesh system that delivers up to 6600 Mbps total bandwidth. Designed to cover up to 5,500 square feet, it features a dedicated 5GHz wireless backhaul, a 2.5Gbps WAN port, and lifetime network security via ASUS AiProtection"
Excellent kit no longer required, I used this to create a more reliable extended network than my Virgin hub provided, using one node next to the virginmedia hub wired directly to the hub and one node in a bedroom used as an office where I needed to improve the signal for working, which just needed power. This worked perfectly. There are three bands, one is the 5Ghz backhaul between the remote node and the one wired to your internet (via your hub/modem) and there is also a 2.4Ghz and 5Ghz band.
£120 posted.
