Auto reroute or does it prompt
GB.
Redneck Norfolk
Still haven't managed to get out on the GS since getting the connect cradle, I've put some routes in ready to try, if you go off route does it automatically reroute you or can choose to make your own back onto the route?
Sadly there is no option to control this in the app currently; if you go the wrong way it reroutes automatically and often it totally messes up the route you wanted to take depending on where the next waypoint is. The more waypoints the more likely it is to stay true as it’ll only recalculate to the next waypoint then “should” be back to normal from there.
That's what I thought, garmin is much the same unless you tell it not to reroute.
