autocom and Schuberth C2
jimswms
Providence, RI
I'm looking for info and detailed pictures, if possible, of how you installed speakers and mic in a C2. Yep, I've seen the instructions on the autocom site, and, yep, I can be a bit thick.
I can't figure out how they routed the wires so that the boom and the main thick wire come out the bottom. did they cut a hole in the lining?
Also, where did you install the mic? It seems like it might be too long for easy placement?
Any tips gratefully appreciated.
cheers
cheers
There is no cutting involved, the mic is thread through the cheek strap and attached to the inner part of the cheek pad via some strong masking tape or velcro. Make sure you do not feed too much of the mic through or you will block the sun visor mech and it will become very stiff. You want around half an inch or so in the cheek pad itself not to block the sun visor.
The main wiring spider is held in place by the cheek pad, whilst you have got the cheek pads out fitting your speakers you can fit the loom as you refit the cheek pad.
Hope this helps you.
