Autocom + Navigator 111 +phone +music
karlp
Southampton, England
Just bought a Super Pro AVi and need to connect the above via wires if possible.
Any ideas what i need.
Phone is Nokia E65 and hopefully iPod.
Sat nav is BMW Navigator 111.
thanks
karl
thanks
karl
You'll need part number 1282, an isolator for the GPS to plug into before the Autocom unit, this will eliminate any buzz in the system
Also part number 1273 which is a bluetooth adaptor for the phone. You could Bluetooth the phone to the GPS, I prefer to leave it seperate and just have the adaptor and the Phone Bluetooth'd so the GPS stays connected via a cable.
HTH
Mark
If you power the iPod from its internal batteries, then you can use the standard music lead that comes in the kit without a problem. If you bike-power the iPod, then you will also need to interpose the 1282 lead to suppress "buzz" from the bike's wiring system.
I would suggest the 1273 lead to Bluetooth the Nav III into the Autocom - but ring the factory to check that your particular unit is set to provide power through the Aux1 socket. Then pair the phone into the GPS.
The disadavantage of this method is that you have to have the SatNav switched on to use the phone. The previous respondent has overcome this by using a separate cable for the phone.
Our parts 1285 and 1294 will connect the GPS side of the Nav 3, a Part 1273 can then be used to connect your phone via the Nav 3 for the calls.
If the ipod is just going to run from its own battery the standard music lead within your kit will be fine. If bike powered you will need a Part 1314 to elimate any ground loops.
Rich :beerjug:
