Autocom/Sonic interface??
Bryn
Moderator
Moderator
South Leicestershire
Got a 7 pin Autocom set up on the bike.... is there a way of plugging in a Sonic equipped helmet into the Autocom system?
I'm talking the round push in type connector found on Sonic installations .... is there an adaptor?
There's nothing obvious on the two websites so comments appreciated :thumb
(Got a couple of system 5's with autocom fitted, but also have a pair of multitec's with sonic fitted :augie) Was just wondering if its do-able
Unfortunately not, the headsets are very different and you would be coming down a lot on the overal performance on the headsets if used. Also the way your system has been designed the noise cancelling is split 50% on the mic and 50% internally on the system. So if a third party headset was to be used the noise cancelling would be effected a lot.
I hope this helps.
Rich :beerjug:
