autocom & zumo
  • Thread starter Thread starter Bonnieman
Bonnieman
Hi all
Can anyone help me on this matter.
Would it be OK to connect both my Zumo and Autocom to the auxiliary socket on my 07 1200GS ? I already have the Zumo connected to it. cheers:)
Thanks for that. Never looked at it like that but makes sense it was made to take higher loads:thumb2
I did that and the aux socket kept cutting the power. This might be because the Zumo can take a bit more power to recharge it's batteries and therefore the CANBUS detected too much ampage and cut the power or it could be that the GS battery is a bit of a weak link and the voltage dropped enough for the CANBUS/ECU to cut the power to the auxilary socket. Eventually I gave up and just powered the zumo straight from the battery, this is quite convenient as the power is there as soon as I put the zumo in the cradle so by the time I've cranked up the zumo is ready to go.
BTW I have the latest s/w upgrades on the GS12 so I figured either the battery is a bit weak (most likely) or the zumo can draw too much current (unlikely as it comes with a 2Amp fuse).
Bonnie...I'm with JayGee. I power my Zumo direct to battery. As for the AutoCom, I have a "tankbag" system to easily move between bikes. Here my AutoCom powers via a DIN connector into the socket on my Touratech dash panel. That panel's socket is also wired direct to battery. Never had any problems.
Check over in the Bike Communications section - there are several threads in there about what the best way of attaching devices to the 1200 wiring. You'll want a switched feed as some people have found that some GPS cradles drain power, even without a device plugged in, so connecting straight to the battery might be a bad idea. Either way, there won't be any problems with the power drain, those two devices together won't be taking too much of a load from the circuit.
GPS wiring.
Me too, but without the Autocom :(
It powers up fine on the 650gs but when I put it on the 1200 it kept loosing the auxilery power 'IE the Can-bus system kept cutting off the power to the socket':rolleyes:
I'm going to add a socket up front that is powered direct from the battery (I'll also add an inline switch that disconects it)
