Trying to fit an Autoswitch (supplied by Nippy Norman), didn't know about Robs switch until I had it ordered, anyway I can't get the bugger to work and I am at the point where I believe the switch is at fault but just to check with you if I have made a glaring error.
Fitted the switch to the wiring under the Turn signal thing in the fuse box wired as follows
Power taken (Red Wire) from the "Green/Blue" wire (a volt meter confirms power on ignition
The Orange wire connected to the "Brown/White"
Black to earth
Purple to the Relay
Now with this set up I am getting a red Led when I turn on the ignition which extinguishes after a moment and then nothing, pressing the turn signal cancel achieves nothing.
I have checked the relay circuit by taking a feed from another source and it works fine.
So what have I done or have I got a dicky Autoswitch?
Black to earth
Purple to the Relay
