Auxhiliary Rear 12 socket
batman1
North Lincs
I have just seen the kit that BMW supply to add an extra rear 12volt socket to the LC, it comes with a loom that piggy-pags into the rear of the front 12v socket.
Has anyone had one dealer fitted, as I would like to know where they actually fit it at the rear of the bike, ie which plastic panel?
It comes with a template, the deal pointed to the front small plastic triangle lower left, which didn't seem far back enough to me.
Ta
Re-check with dealer. The chap you didn't believe. Go on, do it. It's what they get paid for and helps to justify their huge bills.
The extension lead sockets are easy enough to fit. You could (within reason) just about pick your own spot.
Make a plate to carry the socket and / or buy one of the generic socket carriers from somewhere like Powerlet, who have UK agents, too.
http://www.powerlet.com/shop-by-product/luggage-electrix/LUGTRIX
As per image
Thanks GS-Man, Perfect!
That's where I would expect it to be, the deal referred to the small triangular panel positioned further forward and lower down, which seemed an odd place to fit it.
Also, did a dealer fit your extra rear socket, and did they use the GS optional lead that plugs into the rear of the front socket, I believe the lead costs about £40 squid?
Ta mate!
Dealer fitted not sure about ext but its all BMW kit so I expect they did, glad this helped you. Believe it piggybacks of the front power socket lead if that helps you.
Ta mate!
As per image
I haven't fitted a second socket on mine yet, although I will want to before the cold weather arrives here in New England. When you remove the rider's seat and look down, you'll see some sort of electronics, and just outboard of that will be the plastic surround where GSMan put his socket. That is about the only place I could see where there is open space between the plastic surround and the electronics, so it really looks like the best spot.
Rather than use the BMW 2nd socket and piggyback off of the front socket wiring, I intend to use a powerlet socket wired directly to the battery (albeit fused). I am doing it this way for two reasons:
1. The socket will not be subjected to canbus limits on current draw. I don't know how much my electric vest pulls, but I don't want it to be shut down by the system.
2. I will be able to plug a trickle charge into a socket wired directly to the battery without the canbus shutting it off.
I run heated jacket and gloves from this socket at same time without problem
Hi GS-Mam, that's very helpful many thanks.
Emoto, the beauty of having the device piggybacked into the front socket is that it will switch off with the ignition, however I believe that you can use the front aux socket for charging the battery, perhaps someone can confirm that this is so?
I think that I have read it in the handbook.
If it's only use is for a heated jacket then I don't suppose this matters in your case :thumb
That's good to know! I don't know what the limits on current draw are. I do know that some people had the sockets shut off on them on the prior gen 12GS. I don't know what brands or what that they were running. If you have a passenger on board and both of you are running electrics, I don't know what happens with the new bike.
At any rate, here is the result of me puttering about in the garage yesterday:
I installed an accessory socket today. The Powerlet low clearance one. I chose this instead of the BMW accessory socket because the BMW one wires up to the one in the cockpit. This means that it is controlled by the canbus and shares the same current draw limitation that the stock socket does, which could be problematic if you wear electrics in the cold weather, depending on how much they draw. Additionally, the canbus shuts off the connectivity of the OEM sockets, and I wanted a socket wired straight to the battery (albeit fused) so that I can attach a trickle charger to it for the winter months.
You need to locate the hole carefully so that there is enough space for the part of the socket that protrudes into the area where it is mounted. Take great care in choosing this spot. I used a 5/8 drill bit and then hogged it out with a knife little by little until I had the hole large enough for the threaded portion to fit through.
As you run the wiring back to the battery, you'll note that with a little lifting and flexing that you can route the wires under existing bundles.
With the seat height forward adjuster pulled out of the way, it is easy to see that there is a "tunnel" of sorts that wires use to leave the under seat area. You want to run your wires through there.
As the wires run through that tunnel, they rest in a sort of plastic tray. The tray has a notch in it, and that is where I suggest your wires exit the tray and head down toward the battery. You may find that pushing a wire through the tunnel along the tray is a little easier if you pull down slightly on the tray, from the side just above the battery.
I also added a splash-proof inline fuse holder to the leads, for safety's sake. You can find them at any auto parts store.
Take extra care when attaching the positive lead. I chose to attach mine to the jump starting pin. I noticed that the area it is affixed to is insulated with rubber. It appeared to me that you need to be careful here or you will inadvertently ground the positive to the frame. :yikes So, use an appropriately sized eyelet and be careful with the angle and routing.
The current GS range (and my 1600) are both limited to 5 amps, giving about 60 watts.
Heated clothing listed at less than 5 amps may still cause the system to fail to safety as they draw may well more than five amps on first heat up.
On another forum it was pointed out to me that the little electric air pumps that some carry to inflate a flat tire will cause the canbus socket to go dead immediately.
Most probably.
Compressing air is not easy, as winessed by Tossers getting hot using a foot pump :D
It's easy to guess that a modest compressor wiill draw more than five amps.
Alternative method
Was considering how to connect my (non can-bus) optimate 3+ & mini compressor to the GS after finding out the handlebar socket is unsuitable for either!
I've got a weatherproof Optimate lead, so have connected it to the aux battery terminals behind the LH triangular panel.
After searching eBay, I've found a firm selling Optimate type (TM?) plugs & sockets
(£1 per plug or socket or £2.75 for 5 pairs!) so Ill put one on my compressor.
Not 100% sure if the blade fuse in the charging lead will be suitable for a compressor?
What size should it be please?
Power Socket
My heated jacket and gloves are KEIS, not sure of how much power use, I have also run a charger for I-phone , all with out any problems,although mate ran compressor and this tripped can-bus, so wired direct to battery.
