Auxiliary light problem?
47Steve
North East, next to the Rusty Angel
I have a GSA1200 2012. One of the Auxiliary lights (RHS) has stopped working. I thought it was the bulb but tried others and found the fault to be that there is no power (multimeter) from the harness lead to the bulb.
I have checked for breakages in the lead up to where it goes into the main harness but cannot seem to find a fault with it.
Can anyone suggest other issues I could try?
TA Steve
The Auxiliary lights on a TC are on 2 separate fuses and are the only 2 fuses on the bike.
The fuses are located under small plastic pull off panel behind your left knee as you sit on the bike.
The fuse holder is just above the vin plate.
The relay is common to both lights so I doubt this is the problem.
The relay is located under the ECU`s which are under the fuel tank.
The power comes from the battery through the relay then the 2 fuses to the 2 lights.
That':beerjug:s a fantastic concise answer and resolved the problem. Thank you very much.
TA Steve
