For Sale Avtex AMR985 4G Mobile Internet Solution
vtr1000sp1
leeds
£235 posted, happy for collection (Wetherby, West Yorkshire)
Removed from caravan due to upgrading to 5G setup.
You will get:
- Avtex AMR985 Router and power hook-up lead
- Avtex 5g ready antenna
- 3/4 tube of Sikaflex for installing onto a caravan/motorhome roof.
Dead easy to install once you get your hear around drilling a hole in your rig :p
Full spec and user manual here
Antenna:
3G/4G/5G compatible antenna.
High gain.
Low profile omni directional MiMo antenna.
Works in motion or stationary.
Router:
12V/24V mains operation.
4G LTE Cat 4 with speeds up to 150 Mbps.
4 x Ethernet ports.
Connect to existing Wi-Fi network to reduce data cost.
Dual SIM ensures coverage and reduces roaming cost.
E-mark certified for automotive installations.
Remote management System Support.
WAN failover - automatic switch to available backup connection.
Wireless Access Point with Hotspot functionality.
Technical Specifications:​
Router:
CPU: 550MHz.
High Gain: 698 960MHz: 5.dbi / 1710 2700 MHz: 9.0 dbi/4900 6000MHz: 10dbi.
RAM: 128MB, DDR2.
When we go away in the van we usually have 4 iPads, 2 work computers, 2 iPhones, and 2 Fire Sticks concurrently hooked up to this without a problem. I truly believe a proper setup instead of using your phones internet gives better results... Here is a screen shot of speeds on my new 5G setup (NOT THE AVTEX SETUP)- exactly the same environment. Should have done a before and after for the upgrade!
