It's my neighbours(And I gotta ask - why blank out your bike plate but not your car???)
Man you're going to town with that idea!! I know people do 'acf days' and have their bike pro sprayed like you're away to but to be honest what i did was -
Bought the bike - 2006 12gs
Had the bike delivered
cleaned it better than bmw's valeters
spent £12.99 on a can of acf 50
spent around 7 mins (as long as the can lasted) carefully spraying everything that looked like it could corrode and coated it with a good thick layer
What i'll do from here on through winter -
Rinse with cold water from hose pipe after every wet / salty ride
Spray liberally with FS365 after the above
Around christmas break i'll re-do bike with another can of ACF-50 and repeat FS365 treatment and rising etc after riding
And in spring.............wash properly......and..........Taaadaaa!!
Or at least thats the idea! Its worked brilliantly over the past 2 years on my TDM with just FS365 so i would imagine the results will be if anything even better with use of ACF50.
Best of luck!
Fire.
I wouldn't spray it onto any naked flame.
Especially the sun.
I definitely wouldn't go spraying it on the surface of the sun. Or even inside an active volcano.
HTH
Don't spray it on the wife, she wasn't likely to rust and you'll be unable to grasp her firmly at important moments.
Very true, it would probably react with the baby oil.Don't spray it on the wife, she wasn't likely to rust and you'll be unable to grasp her firmly at important moments.
Oh, and it's much easier to apply if you first squirt it into a container and then brush it on
Andres
