Andy Rob
Please could you advise on the following.
I have a 2002 Adv and went to go for run out last night with trusty GS and t,other half.
Bike had drained battery so after removing optimiser and refixing tank in place flashed the Adv up to find running a little rough. Left it running for a while dropped choke only for bike to die.
Decided a quick blast was required so jumped on run round the old block to return to find still not running at all as should and still cutting out without choke.
Doulble checked fuel lines not snagged crushed after replacing tank and then run up again.
Next bit concerned me... Whilst tweakin throtle and watching revs other half spot CAT red hot and heat is effecting rear tyre. Swithed engine off and cooled with garden hose.
Your thoughts please.
Any thoughts before I ring BM garage.
Last out on major run bout 5 weeks ago but have run up in garage no prob
