Bar risers
  • Thread starter Thread starter Fulachtfia
Fulachtfia
Has anyone successfully fitted Nippy Norman bar risers to a pre '07 GS without the fork slider bending the brake cable as the forks are turned to the right? I know the destructions are to re-route the cable behind the slider, but this is not a cure.:nenau
The destructions fail to mention that the clutch cable needs to be re-routed also to prevent it being stretched as the forks are turned to right.
Any insights gratefully received
