Battery Change
John B
sudbury suffolk
Right, stupid question time, I have a new battery to fit, I have done this in the past but the last battery has lasted 10+ years so being old I have forgotten what I did before:rob. I'm assuming that it is the simple procedure of undoing leads, replace battery re-attach leads but I also have a nagging thing in my head that there was a procedure to 'prime' the motronic but can't remember what it was:blast I have done a search but nothing relevant came up:nenau anyway any thoughts? Cheers:beerjug:John B
I did mine over the w/e so it's still fresh in my mind :thumb2
Once connected back up turn on the ignition. Do not start the bike. With the ignition on, fully open and close the throttle a couple of times. Turn off the ignition.
The TPS's are now calibrated and you can turn the ignition back on and start the bike.
Andres
Andres, Thank you so much, as soon as I read your reply I remembered, so not senile yet:thumb Cheers:beerjug:John B
p.s. cracking site where else do you get this level of knowledge (and squit sometimes!)
