Hi chaps,
Looking for a bit of advice here - my R1150GSA is being a bit naughty at the moment. Sometimes it will fire up straight away, others it will give me the impression that the battery is dead. I've had the fault for some time now, but because I can apply a "temporary fix" (take off the seat, fiddle with the battery lead until the circuit is good then hit the start button!) I've not done much about it. It's starting to nark me now though. I've just replaced the battery with a MotoBatt 4 terminal jobbie, as the old battery wasn't holding a charge so well anymore.
Anyhow, I know it's the neg term lead that's an issue. Has anyone come across this before? I know the term lead is part of the whole cable harness, and don't want to go to the extreme and cost of replacing the whole wiring loom - it's a 12 year old bike at the end of the day, so I'd rather know if there's anything I can do first?
I shall check the connection again when I get home today from work (as long as it gets me home!), but I think it's actually the battery terminal lead itself and not the physical connection at the terminal.
Good advice gratefully received!
