Don El Eee
Advice please...
I went to get the bike out last week, switched on the ignition, the LCD was working but only got a high speed whirring noise when I pressed the starter button. A quick look on here suggests the battery is buggered so I ordered a new OE battery and accompanying charger. I've now installed the new battery exactly as per the old one and connected the charger via the under seat accessory socket but I keep getting an error message on the charger after about a minute.
The bike is an 07 GS. It has an Autocom wired into the under seat accessory socket and heated jacket wired direct to the battery. Les' HiD main and spots are wired behind the beak.
I've connected the charger to the accessory socket, plugged it in and then switched the ignition on and off. The charger power light is on and the 0 light comes on but after approx a minute the 0 light goes out and the Error light comes on. I've tried the old battery and still get the same result.
Any idea what the problem is?
Thanks in advance.
Thanks in advance.
