Beer mat drawings
At unladen rebound, and certainly if the damper is providing the stop of travel at rebound, isnt the joint under tension then? (an extreme example would be if you "get air" over a jump say)
Just saying (but I agree the weld is adequate anyways)
:D
Hmmmmmmmm,I have two wheels now:clap
We have also taken a closer look at the rear wheel clearances,
It was decided it would be a good idea to extend the cut out down the arm ,
This will allow us to build the wheels with a lot less offset ,if a 120 tyre is fitted to a 2.5 inch rim.we can get away with 5mm offset,
A standard 2.15 rim and a 4.00 x18 tyre won’t need any offset:thumb
Bit more progress has been made on this one,
It can go for its exhaust next week.:D
I made up a seat base using fibre glass,
And my upholsterer has made up a foam and cover ,Alicante on the top with leather sides.
Going to exhaust fabricator in the morning:D
Oh yes,nearly forgot,,
The motor is just about finished,
This is a 79 RS motor,heavy flywheel,so the bike should go well:cool:
The gearbox is also built,it’s on the shelf underneath the bench
Once the exhaust is finished the bike will come apart so the frame can be powder coated,
I’m hoping to show the bike at the Airhead gathering in Lincoln,where it will have a FOR SALE notice on it.
If this bike is of interest to you ,now would be a good time to contact me.:thumb
Today is a big day for this build,as the frame has been powder coated :clap
Super job from” Alloy engineers” in Nottingham.
Dropped off yesterday morning and delivered back today:bow
Pdm60 for the electrics and a lightweight lithium battery:cool:
Unfortunately parcel farce didn’t deliver today so I don’t have a clutch to fit:mad:
But I’ll stick the swingarm in for the time being
Plastics can go on
And the front wheel :D
And the exhaust can go on.:cool:
Starting to come together now but I’ve run out of parts and it’s Beer o clock:D
Box of parts turned up,
Hard to believe there is nearly £900 worth:eek:
Not a cheap game building specials:D
