Best bluetooth for Nav 5 GPS
ianran
Here and there
Ok, I've got a pair of Scala G9 which I have struggled to get working usefully between myself and SWMBO. I know have a BMW Nav 5 which doesn't seem to run well with the Scala. Doe anyone use a system that works well as both an Intercom and sat nag media player?
The Scala keeps slowing down the Nav 5 and the media player works only intermittently playing a weird clicking noise!
i use the Sena 10r ..never misses a beat and works very well , I connect my iPhone to the nav then the headset to the nav ..so any incoming calls i want are logged up on the nav and into the headset . The nav only connected to the sena works superbly.
Thanks for that, does it have the ability to use in ear plugs?
I'm pretty sure you need a different harness that clips to the helmet for in ear monitors. (My 10s did)
I have the 20s, and that has the 3.5mm socket for in ear monitors built into the harness.
yes it does, you can order a separate lead that has a 3mm socket on to take iPhone type plug in speakers if required. you just disconnect the helmet speakers and wire in this other lead. hope that helps
