As I've got the beast well and truly stripped down for a major rebuild I think it's prudent to replace as many bearings and seals as I possibly can.
Anyone have a good source for all the different bearings on an 1100 GS? Basically I shall be needing:
Telelever arm bearings.
Engine rear output shaft oil seal.
Headstock taper? bearing.
Front & rear wheel bearings.
Both sets of shaft bearings (front gearbox moount & rear final drive mount)
Anything else I, or you lot can think of that could do with replacing. The bikes done 60k, it's having a new(er) engine from an 1100 S put in along with Ohlins front and rear, so with all new bearings in it I reckon it should be as good as new (well, better hopefully).
Ta
Ta
