ciderman gs
after draining the bevel box oil the drain plug was yet again full of bits i had changed the big bearing 4000mls earlier after a failed big bearing (28000) so i stripped the box off and found play in the input shaft after a phone call to steptoe (who was busy but still gave me 5 mins (thanks)), i had trouble breaking the input shaft nut 36mm 200nm and the oil seal/bearing preload collar 160nm so i took it to the local main stealer who said they where happy to break the nut and retainer, after 2 days i went back and they refused to repair the drive and suggested that i buy another one 2nd hand as it would cost too much to repair and they did not want to warrant the repair as it had chewed up a big bearing in such a short time so there must be something wrong with it.
to repair the bevel box you need:-
1 big battery/ air impact wrench 36mm deep socket and bmw special tool for the oil seal retainer
2 old wheel bolts
3 a good blind bearing puller
4 a gas torch with a very controllable flame for heating (soft enough for heating to harsh a flame will burn your paint HEAT GUNS DO NOT WORK ON THIS AREA
5 prussian blue for checking gear mesh
i have now replaced all the bearings and the gear mesh is right by the book the bearing that had failed was the needle roller at the end of the input shaft and this is where all the bits were coming from.
the workshop manual states that if you are not replacing the gear set then you need to check the measurements but as a foot note bmw uk do not stock any input shaft shims so a straight bearing replacement is in the realms of the home mechanic
2 old wheel bolts
I thought he was heating up the bearings to get them to fit back.
